serpentine belt part number
TXHusker
Edmond, OK
Running a 93 Mustang without A/C or Smog, just powersteering.
anyone running this too? what belt part number did you use?
bigmuddy
Marthasville Missouri
I ran something similar before going to the Explorer serpentine. I can look tomorrow when I get home and see if I can find the belt number I used.
Ben
TXHusker
TXHusker
Edmond, OK
belt
not to alter the direction of my own thread....
What is the advantage of the Explorer serpentine setup?
Will that bolt directly to my 93 Mustang 5.0 setup?
gddyap
Mtn View, CA
Run a rope around all the pulleys in the route the belt will take. Measure length of rope used. Be sure to pull it tight and you might need to subtract a little bit. It took me a couple of iterations before I got the right size. Would have been better if I had just bought a few sizes the first time instead of going back and forth to the parts store. The tensioner should allow you to be off by a little.
TXHusker
TXHusker
Edmond, OK
great idea, thanks!
Skiddy
shorter, and allows more clearance between the radiator and fan
