I am doing a frame off resto. I have a 74 frame and a 77 everything else. I am building a mixed use daily driver with some light off roading in mind. My frame is blasted and painted and I am just starting to bolt stuff to my frame. So, a few questions.
1. I grabbed the bolts that hold the spring cups to the radius arms and cleaned them up and then did the blackening trick with heat and an oil quench. It looks ok but how long will that last? So a general question, not just the spring cup bolts but for the rest of the frame too. Do you guys reuse the old nuts and bolts or do you go to the hardware store and get new zinc treated nuts and bolts.
2. Torque spec on those? And all the other nuts and bolts? Is that in a bronco service manual?
3. Thread locker? Or anti seize? Or naked?
4. I have the original radius arms and the PO lost the bolts that hook the C cap to the radius arm, so he undersized new bolts and put nuts on them which of course mashed the threads on the radius arm. So I chased those with a tap and they seem ok but of course the threads are a wee bit less strong than factory. My plan is torque to spec and if they hold, call it good. Comments on safety?
5. I have a 1.5 inch WH lift and plan to use the original nonadjustable track bar. yes? no?
6. I have the y steering linkage and the boots are trash so rather than spend time or money on that, I was going to get a new tie rod drag link setup. Anybody have an opinion on the T style conversion vs the heim? The heim looks good but does it last? Can you grease it?
I have a lot more questions and will save those for a later date. Many thanks in advance.
