DanWheeler
hey guys, i've been reading through all the shackle flip threads and have some questions.
I want to move the rear axle back 3.5". I have removed all my spring/shackle hangers.
If I move both the front and rear hangers back exactly 3.5" and flip the rear, will my leaf spring and shackle hang correctly?
I saw a couple pics of shackle flips that were moved back 3" but their rear shackle is nowhere near where mine would need to be if I moved it back 3.5".
Here you can see where the stock rear bracket was:
and here is the bracket flipped and moved back 3.5"
you can see why 3.5" is a good number to go back because it puts the edge of the bracket between 2 holes in the frame.
and in the front 3.5" just happens to be right in front of the body mount:
so I'm hoping I can just move both brackets back 3.5", flip the rear upside down and everything will be as it was stock but higher and further back.
thanks,
dan
![1105876751_LfPP2-L.jpg](http://dano.smugmug.com/Cars/Ford-Bronco/IMAGE178/1105876751_LfPP2-L.jpg)
![1105876805_QieFn-L.jpg](http://dano.smugmug.com/Cars/Ford-Bronco/IMAGE177/1105876805_QieFn-L.jpg)
![1105876845_vJYks-L.jpg](http://dano.smugmug.com/Cars/Ford-Bronco/IMAGE179/1105876845_vJYks-L.jpg)
thanks,
dan
