- Joined
- Oct 8, 2019
- Messages
- 587
I'm sure you seasoned veterans figured this out a long time ago, but searching I didn't find much. I'm getting things finalized for paint and have some holes in the firewall I want to plug. Found a youtube video where the guy made a tool to punch out perfect round plugs so decided to give it a try. I used 2x2x4" blocks from Metal supermarket, paid $43 for 3 of them. Ordered cheap transfer punches from Amazon in 1/2", 3/4", and 1" and ground the nub off the tip and gave it a flat, somewhat sharp face (kept it cool while grinding). Drilled the blocks and cut a slot for the sheet metal. Slide the sheet metal into the slot past the hole and drop punch in a give it a couple solid swings of the hammer and out pops a nice round plug.
I also found you can order plugs from Eastwood after I started this little project, but what fun is that?
Before I found this I did make a couple manually using the belt sander by drilling the sheetmetal and welding a small nail in the center and turning it on the sander with a drill, but that was a PITA and once this tool is made it takes 30 seconds or less to make a plug.
