Rob Wadsworth
First piece of sheetmetal test fit! Definitely need some advice on removing the old sheetmetal. I drilled as many of the spot welds as I could and used my air chisel to work the seams apart. It was kind of crude and tedious. Some of the spot welds are difficult to find so it starts getting ugly with the air chisel....Should I be doing anything different. Grind the spot welds? Please tell me there is a better way. I have door posts, kick pans and rockers to do both sides.
I am planning to install each piece of sheetmetal one by one then put the doors back on to make sure everything aligns before final welding. Do I start tack welding at this stage or just screw together with sheetmetal screws until I test fit everything? When I do weld, how do I weld the panels together? Spot weld again? I saw a thread showing the panels welded together at the interior seem inside the engine compartment. How about the bare metal at the seams? Does the bare metal get treated before welding the seams together? Or do I just seal when I paint?
