I use .023 wire -- a brand called EZ Grind. It's softer than normal wire, same tensile strength, and polishes right off with a flap wheel. And use compressed air to cool.![]()
Who makes it and where do you buy it?
Growing up working in my Dad's shop, he had these real big magnets that I use tyo attach to the sheet metal close to where I was going to TIG.
Another possibility is to clamp some aluminum blocks near the area to pull out some of the heat.
I have a magnet that sets a 45* and another that you can set at any angle, pretty handy I must say!
I just went to my welding supplier and asked--- He had some in his warehouse and had it the next day. Oxarc supplier.
I love it-- every time I do sheet metal, I put that roll in. It is about twice as much, I paid about $40 a 10# roll as opposed to $20 for normal .023. It's worth it!!!![]()
Fantastic info everyone, this is the level detail and set of tips/tricks I was hoping to get....thank you all for taking the time to detail it out! Hopefully I get some shop time this weekend and I'll post some pics of the results!
To keep the discussion going - any of you use weld through primer to protect from rust - especially on backside/hard to reach areas once the patch is welded in?
I do the metal prep and then get my welder bud to come over and i buy beer. works REALLY WELL ;D
Weld through primer is used before you weld, you weld 'through' it... We use the ez grind wire at the shop, it's supposedly designed for body work and is somewhat flexible after it's welded (at least thats what I was told).
Why 20 gauge? i stick to 16, 18 at the thinnest. most Mig welders work better on sheetmetal if you reverse the polarity.
