Shock boots
kip60
Just bought some shock boots to cover shafts on front shocks. Thought they would be universal, but seem large. When I installed them, they just slid down onto the barrel of the shock. they didn't come with any instructions. See they do have 2 small holes towards bottom of boot. Is there some kind of binder or spring that I'm missing? If so, do they tighten on top of the shock barrel, or above it or onto the shaft itself? Have new standard Gabriel replacement shocks. Boots from Graveyard. Thanks.
thegreatjustino
Red Head Grease Monkey
Stockton, CA
Zip ties on the shocks bodies. The ones I've replaced have the correct size collar to fit on the non-body end of the shock.
Most here will recommend not using the boots at all though as they trap water and dirt.
