Get a base line with the shock length at ride height.. Take the drive side front tire off. Hook a cherry picker to the axle and start to lift. This can get you your rear numbers. Proceed to the rear and lift the driver side rear and you can get the numbers for your front..
This method will only get you close to the end result. Only other way to get them is with a ramp or good ditch to stretch it out in.
