I'm Running Bilstein Shocks,3.5 Lift With Duffs Hoops, With 35"s Front And Rear Bumpers Each Run 100lbs Each.will It Be To Much To Run Two 255/70 Bilstein Valving Shocks On Each Corner.
you only want to run one with that valving,the 255 is the rate plate on compression. its higher than normal so one will be enough, 2 will be too stiff.
