Z Bronco
- Mar 17, 2007
- 1,141
After searching the forums and still having some questions, I figured I would see if anyone here has a similar setup to mine and find out what shocks are working well for them. Below is some information about my Bronco, my driving style, and what the Bronco gets used for. If you have a similar setup with experience on brands of shocks and valving, your input will be great.
The suspension (new):
Front: WH 3 1/2" rock crawler coils, degreed rubber radius arm bushings, extreme duty coil cups, and the Extreme shock hoops.
Rear: WH 3 1/2" leafs, WH Extreme duty U bolts, WH super shackles, WH Shock Jock (not welded in yet).
The Bronco (and the added weight):
Front:
-Hanson 3/16" plate bumper
-Warn 8274 Winch
-351W EFI with explorer serpentine/saginaw setup
Back:
-Hanson 1/4" plate bumper with full size 35" spare and rubicon racks
-23 gallon BC EFI tank with a 3/16" skid plate.
Mid:
-3/16" square tube rocker panels (4" x 4")
-12 gallon NWMP aux tank with a 3/16" skid plate
-BC 3/16" belly pan/skid plate
Driving style and uses:
I drive my Bronco to and from trails, and across the country as well. On the long journeys, I often tow a M416 military trailer loaded with camp gear. Most of the trails I travel now are of the rock crawling variety. Before I added all the weight I would launch my bronco off the top of sand dunes and blast through desert roads. Now, mostly trails and exploring, with maybe occasional aggressive driving. Example of trails that I have been on are the Dusy, Rubicon, Tellico, Moab, Colorado, and the fun in Gore, VA with the MEB group. Once back up and running again, my Bronco will also be my daily driver.
Shocking questions (Hey, it's October!):
-If I double shock, I am looking at either the WH shocks or the James Duff shocks. Both make shocks that will fit my shock mounts and suspension travel. I had great success in the past with Doetch Tech MV 12s and the soft valve Rancho 5000s, but neither of those are in sizes that fit my shock mounts or suspension travel.
-If I single shock at each corner, I am looking at the Bilsteins or maybe the Rancho 9000s. My question on the Bilsteins is what valving would be the best for the front and the rear given all the information on my Bronco and driving style.
Almost forgot, tires are 35" BFG Mud TAs on Ultra aluminum rims (15 x 8).
While I welcome all feedback, I am especially interested in hearing from those whose Broncos are similar in weight and uses to mine.
Thanks in advance for all your feedback!
Z Bronco
Front:
-Warn 8274 Winch
Back:
Mid:
Z Bronco
