Shocks
broncobillyusmm
Mountain Home
Wild Horses 70/30 shocks vs. Rancho 9000x shocks
I was wondering if someone who has had both type of shocks experienced a different ride quality with the same suspension. I currently have the wild horses shocks. I have dual shocks all the way around with hoops in the front and added a shock mount to the rear. All bushings, springs, and coils were changed to new. The bronco has been restored for 3 years but only has a total of 6,000 miles on it. Any input on to the ride quality of using different shocks? Thanks.
eds66bronco
Essex, Vermont
i noticed a huge difference going from two on each corner to singles in the rear. i'm running the duff shocks. i'm currently using a home brew inboard rear mount (like the Cross ent. setup) with singles in the back. the back was bone jarring with the stock type rear mounts and duals. removing one shock helped but articulation sucked so i built the inboard setup. i havn't noticed any instability or body roll and i use mine as a daily driver in the summer.
this winter i'm doing the f250 front mounts and will try a single in the front as well.
DRBRONCO69
Chicago Mike
Chicago, Illinois
I run the Duff shocks also. Single shock setup up front with f-250 mounts. Shock part # is 8120 Duff 15" travel. Nice front articulation. Rear is stock mount with Duff #8110 10" trave shock. Articulation is good but I just purchased an inboard shock mount. I am planning on buying another set of Duff 8120's for the rear. As far as ride quality, it handles awesome on the street with very minimal if any body roll. I couldn't i9magine having quad shocks all the way around. I would think you would feel every pebble in the road. I like the mushy feeling better. My .02;D
ctowery
Wellington Nevada
I have had 9000's and now have Bilsteins...no contest, get Bilsteins! All you need is single unless your racing.
If you need help selecting them PM me.
Disclaimer..I am a Bilstein dealer ;D
Cary
broncobillyusmm
broncobillyusmm
Mountain Home
Ok it sounds like removing the added rear shock should increase my ride quality. Will removing the shocks increase axle wrap? That is a big concern of mine because I have already broken 2 rear u-joints. Thanks.
eds66bronco
Essex, Vermont
yup, it could increase the amount a little but if you've busted two joints already, i'd venture to guess that something else is up with the rearend. i'd start with checking the pinion angle.
ctowery
Wellington Nevada
Unless the shock is mounted in front of the axel it will have little to do with controling wrap...something else is the problem.
Have you checked the U bolts?
What brand of springs..lift?
What is your static u joint angle ?
What brand of u joints are you useing?
Your not overtightening the u joints....
More info on your EB would help
Cary
broncobillyusmm
broncobillyusmm
Mountain Home
ctowery
Wellington Nevada
front shock mounts from a pre 99 ford full size truck.
Truck pulls!!!!!! That bit of info would have helped! Stock u joints and truck pulling....Boom!
Cary
