Show me your side mirrors
BoltBuster
had one break, can update or go back with stock. Show me your mirrors ;D
PS Who sells a decent replacement mirror?
SaddleUp
Vancouver, WA
I've been running CJ 5 aftermarket mirrors. Originally I used a set of steel painted ones. One of them broke off though (Partially due to rust at the mount) and then I lost a mirror head somewhere between Seattle and here so I decided to go with stainless this time. (The price difference was about $2) If you do go with these you will want to add small plates in the corner of the windshield to add strength. I used small pieces of diamond plate. I took a few pics yesterday but blew it on my camera settings so they didn't turn out very good. I'll be taking more this weekend which I'll be posting in the SaddleUp before and after thread along with the rest of the stuff I've done recently. Here is one of the ones I took yesterday but it is pretty washed out so it is hard to see really well.
ransil
Roll cage mounted.
If lookin' for stock mirrors try the Ford dealer, last set I got from JGB are in a Ford box.
edge4
Gonzales, Texas
You can find these metal swingout mirrors on Ebay all the time for around 20.00 each.
Fathom
Los Angeles
I made my own mount ;D
frigr8
Va
One of my mirrors..
SaddleUp
Vancouver, WA
Here are some better pics of the CJ mirrors I have on mine.
73stallion
Eugene, OR
here's mine, they're CJ-7 stainless and i made my own mounts. i already had the light mounts i made 3 years ago, so i modified them.
Western Okie
Leedey,Oklahoma
Hey Saddleup...I`ve got a set of Cj-5 mirrors that i havn`t installed yet. How thick of plate did you use and did you use self tapping screws???
Thanks,
Matt
SaddleUp
Vancouver, WA
Thanks,
Matt
Not absolutely sure on the thickness. Perhaps 1/8" Aluminum Diamond Plate. I have some stainless diamond plate as well but it is some tough stuff to cut whereas the aluminum can be cut with a skill saw. With better equipment I would use the stainless. Each one is L shaped so it extends out onto the bottom and up the side going over the seam in the windshield frame to add strength there. Can't recall the exact size for the screws but they are self tapping. Possibly #10 x 3/4" or so. Might even be #12's. Originally I used screws right into the windshield frame but these worked loose over a few months so I plated the corners when I removed them for the paint job. One other note. When I did the first set I modified one of the brackets (the tubing) so they both looked the same. I.E. Both had brackets more or less parellel with the body. What I found though is that the right mirror was always a pain to keep adjusted since it needed to be pulled in far enough to see through the right door. Because of this it kept getting hit by all 3 of the doors (1 Hard Door and 2 different soft one). When I replaced the broken one (It rusted and broke where I had drilled it to rotate it) with a new set of stainless ones I instead used the brackets as designed for the CJ. This puts the passenger mirror forward and higher which is then viewed through the right side of the windshield. They have been on there for a week or two now and I haven't had to adjust that one at all since they were installed.
Waverous
Aurora, CO
here is the mounting set up we are using
adunham
Phoenix, AZ
Terry -
That is exactly what I am looking for! Painted white, round, fender mounted. Any idea if there is a source for OEM or aftermarket replacements?
66Bronco
adunham said:
Terry -
Unfortunately I do not. I feel I was very lucky to locate the ones I have back in the mid '90's through one of the companies that sell NOS Ford parts. Once I did see one on Ebay. Btw, these mirrors are easy to disassemble so finding one that's showing its age can be easily made to look new again. Good luck!
-Terry
sprinksbeme
Kingman, AZ
I was looking for mirrors and saw in JC Witneys catalog mirrors very similar to 66Broncos ( sweet ride ) the part # akk8870225n they list them as replacements for CJ2A, 3a, 3b, CJ5 & 6 $15.95
Marty
BUCKN71
Washington, DC
I just got off the phone with Chris from Off Road Innovations of Centennial in regards to the side mirrors that he posted on his rig (see post #14). There has been a lot of talk about side mirror options recently on this site. My two cents is that Chris's side mirrors are hands down the best option that I have seen. It looks awaesome, would be a quick install, plus you can remove them and run your original mirrors when the doors are back on. Chris was real nice and told me that he would send me an estimate for the complete system. I will post the price when I recieve the quote. If you have an interest contact Chris at 303-680-9077.
jdevon
Dallas Area
excellent! thanks for the leg work. i was looking at their site, but having problems opening the pages. those would be perfect for me.
