Side Step Fabrication
PCRammer
I know there is always periodic discussion of who is doing what for a side step. I thought I'd share what I and a pro welder came up with. Of course this is unfinished. These will be anchored to the vertical floor braces located just inside the rocker. The welder has the template set up so he might be able to produce these if anyone wants his number...im sure he would need to get some measurements from you. He's in NW FLA. Its basically a 2x2 square tube, 1-in step down to a 2x1 rectangle tube.
