Side View Mirrors????
broncoitis
Saw this 66 for sale on Auto Trader and really like the look of those side view mirrors! However, have no idea what they came off. :-[
Any of you have a guess? Possibly a later model Big Bronco???
Hopefully that link works!
broncoitis
broncoitis
:eek: Aw, come on now! They don't look that bad. I think that they would look better painted to match the body but overall I don't think they look outta place. However, I have to see if there is a pick from the front because those pics are from the side! ;D
Makes it look like Dumbo the Bronco!%)
Heus33
Herman is putting a set like these on his Bronco - I'm sure he'll chime in shortly.
HGM
Senoia, Ga.
Yep, same as my '94 F-150.. Even the steering column is out of an early '90's F-series, pre airbag.. I always find it funny that someone will ask $30k for a 44yr old vehicle with just a breif 3-4line description.. That things had much more work than the ad states..
broncoitis
broncoitis
Yeah, right! Definitely some money invested in that Bronco!
Just think that the Mirrors look pretty good compared to some that I have seen. On top of that, I thiink the Jeff's Bronco Graveyart sells them new for like $40. ;D
Are the 94 F150 mirrors and Bronco mirrors the same or slightly different? My guess is slightly different with the F150 being a bit more streamlined I guess! %)
W650Mike
Eastland, Texas
sprdv1 just bought a rig with some good looking mirrors. Hopefully he'll chime in on what they're off of.
I'm looking for something better than stock but not out of place on the EB.
broncoitis
broncoitis
Thanks HGM! I think that sounds about right for the years!
Would love to see some other options though! Not stuck on these just liked the look and not the same ol, same ol mirrors that are usually used. :)
Same, even the doors..
BTW, your looking for '92-96.. Or even a '97 F-250HD
Justafordguy
X2, FSB and F series trucks used the same doors and mirrors from 92 - 96. My 94 F150 has these mirrors and I think they would look good on an EB. You can but them cheap on Ebay.
NY-Bronco
Resident Dipstick
Weehawken, NJ
That silver Bronco was one of the many inspirations. Its a meticulous Bronco but the price they want seems a tad high for me. Its been on ebay numerous times and popped up in various for sale sections also.
I got the 1996 F-150 mirrors. I wanted the one with the blinker/indicator but could not find one.
I liked those mirrors and I am committed to putting them on now as I have made the cut. to accommodate the "arm" that comes with the mirror.
Due to the shape of the mirror it has to be moved from the stock location otherwise they will point upwards.
The one thing that I found to be a slight main to make was a gasket. I went to an industrial rubber supply store and bought various grades and hardness of rubber and neoprene. They need to be combined to provide both a seal and stability.
The mirror gets mounted with three screws. Two on the front and another through the otherside of the door that holds the arms.
Visibility on the mirror is awesome! And it does not hurt that its electric either. The harness is super easy to deal with and switches are abundant. Steveo and Tasker were kind enough to send me the diagrams etc. Thanks guys ;D
Ill take pics later this week with them mounted and you will see them firsthand soon anyways ;D
edit: They fold which is a nice option
broncotime
Grapevine, Texas
Yup early 90's ford truck mirrors. That's what I put in mine. I hated those tiny stock mirrors and these were a huge improvement.
broncoitis
broncoitis
Nice looking Bronco! Always been a fan of Yellow and the Mirrors look NICE! ;D
broncoitis
broncoitis
NY-Bronco,
Looking forward to seeing your progress and those mirrors! I think that I may going with those as well in the future. Just like the look and anything is better than stock. ;D;D
NY-Bronco
Resident Dipstick
Weehawken, NJ
I dot mind the look of the stock mirrors. I actually quite like them. Mine were not stock to begin with. The ones I had may look nice but at higher speeds they would move and I dont like the fact that you can not fold the mirrors in. In the area where I am at you need folding mirrors unless you want to loose them to some douchebag not paying attention.
red hot71
kent wash.
I used thous mirrors on my 72 and liked them very much,a couple of other points to add.If I remember the large center hole I drilled I think in line with the back vent frame and it didn't allow full opening of the vent window(it open about 2"),so next time I'am moving it back 2"? to allow the vent full motion,so check it. Also the center support that goes inside you need to add a 2-3" 3/4x1/8"flat bar to tie that bar into the door makes it very solid. I have a second 71 that I'am using the same mirrors on.I had the mirrors color matched with the chrome fronts but if I had to do over and all black wasn't the color of choice I would of used the black ones and color matched and making them all one color,(personal taste).The explorer mirrors are of the same design but smaller it looks like the base mounts mite interchange? If you look at the trend on newer suv stuf they tend to have larger side mirrors these days,and once you use them you won't go back
