Here is the other problem, from the sounds of it, you guys dont like sky jacker. Now I wont be doing any rockcrawling, being that there are no rocks here in NE Ohio, but alot of mudding. This suspension retails for around 800 bucks, I can get it for a little les than four, its a true suspension lift, not blocks or anything, what about that? Also, because I have a 66', and the suspension is for a 67', (different rear shock mounts) will there be a problem making the drop pitman arm functionable? Are there other differences I am not aware of? I have the 170 st six under the hood, if that helps you identify it.
