75Bronc
- Feb 5, 2008
- 425
I have a serpentine 351w from a 1990 F250. It has the F250 front dress. I got a junk yard power steering bracket with a Saginaw pump from an E350. It lined up perfect.
It doesn't seem like I have the steering power I use to with the original bronco pump.
Could my pump be weak?
Do I need a smaller power steering pulley? Does anyone have a link to one that would work?
Larger Crank pulley?
I run 35's with lockers front and rear. When I am low RPM crawling, my power steering is very weak. I know the tires and lockers make things worse. I would like to add ram assist in the future, but for right now, I feel that I should have better steering. Even on the street at low rpm it wines a little and is a little tougher than it use to be with the bronco front dress and pump.
Thanks!
Thanks!
