Smittybuilt 6 point roll cage
SSDDBRONCO
Los Angeles
Hey i was wondering if the Smittybuilt 6 point roll cages are good. I dont do anything extreme but if it even does turn over (hope not knock on wood ;D) would it protect me and the passenger. Would you recommend it for 200 dollars? Worth it or not.
ET
Dallas, TX
Their cage is alright but you should add more braces. I think the size is either 1.75" or 2" tube HREW. I didn't think they were still making them for broncos.
Eugene
SSDDBRONCO
SSDDBRONCO
Los Angeles
Eugene
no they dont make them for broncos anymore i just found a used one for 200 dollars and wanted some input if they are good cages or not. Is the San Felipe roll cage good? Also Eugene what do you mean by more braces?
ET
Dallas, TX
I meant to add extra tubes to brace the whole cage. I plan on adding two parallel tubes to the top at the center. One across the front legs and one between the main hoop legs. Then tie it to the frame. There's a lot of people that run them as is and I've seen them held strong in a roll. I just want to making it stronger.
Eugene
Scoop
Bronco Old Fart
Cuchara, CO
Actually I'm running an old smittybilt as may main hoop and I got the front kit for the San Felipe from WH. Fit up just fine. I would think the San Felipe is at least as good as the smittybilt, if not better.
trailbound
It will work just fine, and technically there shouldn't be any difference between it and a WH cage. $200 isn't a screaming deal, but good enough if you don't have a cage at all. If your in a roll over (I'm not talking about a rolling, tumbling roll over) it will keep you safe. However because it is made from HREW, if you are ever in a roll, it will have to be replaced afterwords.
Dan's73
I've had the original 4-point Smitty-built cage in 2 of my EB's, one that I added the WH front cage kit to and another that ended up a base for a full "family" cage. Both were good, solid pieces and certainly better than nothing. The one with the WH add-on actually did survive a roll (after I sold it) and, from the pics I saw, looked to have provided really good protection.
regshawn
Portland
This Shitty built.......I mean smitty built cage may be for sale! If it matter's this was a low speed (less the 20mph) roll over in sand, most walked away.
If you get one I would brace it for sure, and would hate to have seen the results from a roll over on the HWY.:eek: It did it's job and no one died, I would also add they are better then nothing!!!
Scoop
Bronco Old Fart
Cuchara, CO
That does not look like a Smittybuilt - look where the back bars attach to the main hoop. Smittybuilts have a bolted connection for the back legs on the vertical section - the pic shows a the bars welded to the horizontal section. So it probably is a shittybuilt - a poor imitation! ;D
72_EB
66to77
http://www.youtube.com/watch?v=B97NLBWoEp8
Ask DRBRONCO69 if he's happy he had that Smitty in his truck. Rollover tested.
That other rollover pic is not a Smittybilt. Like the other poster said, the Smitty rear legs are bolted.
I ran one for many years and added a rear family section from a Protofab cage for many years which worked great with my old softtop. It is on my buddy's truck protecting his family now too. Only reason I got rid of it was because it won't work with my liftgate supports. Ran it too tight to the rear supports. Fit like a glove with a softtop though.
No, they are not Protofab quality, but certainly better than nothing at all in there. Have you ever seen the sides of a hardtop fold over in a wreck? Not pretty. Don't expect that to save you.
For $200. bucks, if it's local, I'd do it.
WILDHORSES
USA
I would recommend it for $200 especially if it's welded together already and you can go to the seller and test fit it in your rig. You will save $ and half a Saturday of grinding and welding. Not that I don't want to sell you a San Felipe but a deals a deal. ;D
Jim
regshawn
Portland
Your right it does not look like one, but the back legs were altered to fit under his extended half cab. I also think thats what keeped the main hoop from folding more then it would have. Like I said it did it's job and was better then nothing. :p Also if it had a rear section it would have helped and I'm sure it would have spread the weight of the impact.
SSDDBRONCO
SSDDBRONCO
Los Angeles
hey sorry for the delayed response but i emailed the guy like 3 times but he never replied so now i need to find another roll cage. might as well just invest into a good one.
