djhudson05
- Nov 29, 2008
- 542
Everything is stock. For some reason, The Accessory wire(Black-green, goes to post on ign switch) is hot, all the time, even when unhooked from the switch When I disconnected it from the switch, the smoking stopped. The wire, Black-Green stripe runs from switch straight to fuse box and it also has a lead that goes to the voltage reg on the back of the instrument cluster. I disconnected the wire at the Instrument cluster and hooked it up at the switch and it still smoked, so i know it is not the instrument cluster. Have to figure out why this wire is hot, even when not hooked to the switch.
Just remembered something, when I first started messing with this, I noticed a funny looking "fuse" in the heater terminal (Black- green stripe). When I pulled it, it was a 1/4 inch bolt with the head ground off being use for the fuse.
