So I'm rebuilding my Power Steering Box
CrazyJoe
San Antonio
Tom's Bronco parts listed a rebuild for $250. It was a small leak, me and our company mechanic thought we could do it. Had to order the rebuild kit with all the gaskets/O rings though.
3-4 tries, several phone calls (turns out the mechanic never did one before and it was trickier than he expected) we got that puppy back together and in the Truck.
However, something is NOT right.
Before we connected the Pitman arm, the wheel turns just fine and smooth as butter. Soon as we connected that, there was some resistance, more than I remember. It became very clear something was very wrong as when we drove it - it took two hands and some muscle to turn. However, it turned fine one more more than the other way.
We found out we screwed up ONE little Teflon ring, and had to order a new one.
Threw it back in.
Again, it's a real PITA to turn, but equal pressure both ways.
We are very sure the rebuild is right. Great guy at Tom's even said that if the pitman arm is disconnected and it turns smooth, then it is very likely not the gearbox. Best next guess is the Power Steering pump decided to go out too - it is 29 years old after all.
While I wait for the new one to get in, anyone else had these issues and maybe got some ideas?
It's been raining off and on all month and I am missing out testing the 4 wheel drive, it's horrible.
BwoncoHowie
C-4 Wizard
Not sure what trouble yours is having but you need to make sure there is nothing frozen in your steering linkage I guess. Ball joints, tie rod ends etc. Maybe you have something under there that is ready to break. If you dont know the condition of your pump and you plan to replace it, perhaps it's time to upgrade to the Saginaw Canned Ham style.
Here is a thread with my adventures in overhauling pwr steering boxes. Then 2Badrotties ;) bailed me out and sent me a cherry rebuildable core.
http://classicbroncos.com/forums/showthread.php?s=&threadid=38072
~BH
U
Unregistered
Guest
where in texas are you? there is a place out side San Angelo called West Texas Off Road. They are very knowledgable on steering boxes and might even be able to help you over the phone. If you want their phone number I will look it up for you.
C
CrazyJoe
San Antonio
San Antonio Texas. Yes, please I'd love their information. If the Pump doesn't work, we'll revisit the idea we did something wrong in the box (which we doubt alot right now). I am also wondering if there is a problem with the bars, however with it up on jack stands the tires turn EASY by hand. That shouldn't be possible if that was the issue.
C
CrazyJoe
San Antonio
Follow up. The Pump fixed A LOT of the tension, howevere there's still quite a bit tension, too much to take it on the road. However, now the tension is tight on the right turn - not the left. Now it sounds like the Gearbox has problems.
* dials information *
On another note - there is a full half-turn of slack in the wheel, whereas before there was only a third to a quarter turn of slack in the steering wheel.
Anyone know how to totally get rid of that slack? Tried adjusting something on the gear box...but not really relying on that at the moment as something is wrong with it I assume.
B
bert
Guest
After you resealed your steering gear, it should have worked just like it did before resealing, only no leak.
The worm gear and sector are what does the work and gets worn. It sounds like you might have them clocked one tooth off, hence more steering play and binding in one direction.
BwoncoHowie
C-4 Wizard
You need to tighten the spanner sleeve where the column shaft connects to the specified preload, then lock down the big pal-nut. Are you using a book to do this? Your sector gear preload may be too tight, try backing it off 3/4 of a turn and cinch down the Nylock nut again, this should loosen up the tightness or the excessive drag you feel. As was stated by bert, make sure your clocking is right. Try to get some shop manual info on the preload adjustments, it will help you gain more understanding on these gearboxes. You can seriously damage power steering gears and turn them into scrap quickly by doing improper adjustments. ~bh
