Softop Question???
broncoitis
Ok, gonna be installing a softop on the bronco! Pretty excited about getting it on there because I used to really enjoy driving my Jeep when I had it with the top down.
Anyway, my question is about installing a softtop without any support for the windshield? Anybody running this way currently? Will be adding a front cage in a couple of weeks so eventually the windshield will be supported but just worried about possibly doing some damage without any support.
Any advice would be awesome.
Baja71
It will definitely pull on the windshield. You can always put a new seal under your windshield by the hinge to beef it up a few mms.
BronCowie
Old Timer
Vancouver, WA
'Been runnin' a softop full time for 2 years now with no extra hardware for the windshield. I am 98% on the road, not off with no issues. I think you need to tie it into a roll cage if you spend more time off-road with the top off, otherwise the top pulls it back and keeps it tight against the doors.
broncoitis
broncoitis
Will a couple of weeks do any damage? Once I get the cage in place I am gonna install some windshield stiffners that should solve the problem. Just worried about doing damage. :eek:
Baja71
Look at the reveal between the door and the windshield before and after installation. If it's pulled back enough to touch the door frames, you could damage your paint. However, if you use a new seal under the windshield, or temorarily add something like foam tape, you may be just fine, short term. Here's a pic of what happened to mine.
bknbronco
North Metro, MN
I asked the same question a month ago and alot of guys said they have ran a softop for many years without tieing it into anything. Like said above if it pulls to far back just put a new seal between the two hinge halfs or double it up under there. The more rubber between the two halfs the further it will push the frame forward.
broncoitis
broncoitis
bkn and baja,
Totally understand what you mean and that is what I am worried about. If I remove the hardtop, there is at least a 1 inch gap between the top of the windshield and the door. Just don't wanna damage the softop.
Honestly not sure what to do at this point. Kinda thinking I should wait till I get the new cage and then put on the softop. Hmmmm, what to do!!! %)
bknbronco
North Metro, MN
Ohhh you worried about to big of a gap????? I thought you needed the supports to push the frame forward?? I think im gona have the same issue when i get my frame mounted permantly. Im hoping the top will pull it right into position because a roll cage isnt in my near future, although it should be even for on the road. I just dont want a off the shelf cage.
Better too far forward than to far back! Are we on the same page now? Id say that the pressure exerted on the top because of the frame would be less than the pressure from having the windows open or the doors off. To pull my frame into correct position dont take too much force. I bet driving with the doors off would creat much much more force.
Baja71
bkn and baja,
Why is the gap so large? Obviously, it can't be that wide with your hard top in place, so it is springing forward when you remove the hard top? Can you push it with your hand into position? What is under the windshield at the hinge (seal)? I'd say make sure you have a factory seal and install your soft top. It will pull back on the top of the windshield.
