dirtbikedad
SOLD 71 Bronco 302V8
Dana 30 front, 9 inch rear. 3:50 open on both.
3spd on floor. PS/PB. Stock height, 32" tires
U15GL J83369
Was originally Boxwood Green according to serial number.
Engine runs really good and smooth but does smoke .
Has headers and cherry bombs for exhaust so it is loud but sounds good.
Body is in great original shape. No rust in doors, door post, rockers, tailgate, inner fenders. Only rust in tub
is the front floor boards and front edge of hood. Have another hood with good edge but needs some work.
Grill has dent on passenger side that should pop out pretty easy.
Has a little damage to passenger side rear behind tire.
Needs weatherstripping pretty much everywhere.
Gas guage quit working, must be in guage itself or regulator on back of guage cluster since everything else is new.
Has SunPro guages for oil pressure and temp.
Wild Horses Gorilla Warflares (new)
New brakes (manual drum)all four wheels to include shoes, wheel cylinders and hardware.
All new brake lines on front
New soft brake lines from frame to differentials front and back
New E-brake cables
New master cylinder and power booster
Kingpins rebuilt on Dana 30 front
New U joints on axles
Extra set of good front axles
New seals on axles front and back
Both front and rear axle disassembled, cleaned checked and reassembled. New bushings on front suspension
New belts and hoses on engine
New plug wires and Dist cap and rotor
New headlight switch
New starter solenoid and voltage regulator
New Motor mounts
New Radiator
New Alternator
New felpro reusable oil pan gasket (still have slight leak in front)
New steel fuel tank, sending unit and pigtail connector and hoses to connect filler and vent (Toms Bronco Parts)
Aux fuel tank removed but still have.
Duffs 3 spd floor shifter.
Have good spare tire carrier but not installed.
New seat belts for rear seat.
Stock seats have been recovered in the past, pretty good shape but not a factory looking recover.
Family roll cage. Have had in but removed with intention of repairing front floor pans.
Stock uncut dash with original AM radio (currently not working but haven't looked at it)
Hardtop is in ok shape but needs hardware for liftgate latch.
Have extra liftgate for top
32" Pro Comp Mud terrian spare not mounted
U15GL J83369
New E-brake cables
New Motor mounts
New Radiator
New Alternator
