- Jul 15, 2005
- 568
I have two broncos and one has to go....the 72 has a Newly rebuilt C4 auto w/ new flywheel and torque converter. Rebuilt Carb with new pre heat tube. New alternator, starter and optima red top battery with quick disconnect. New 4 core radiator, SS brackets, fan shroud, new hoses and overflow bottle. Rockyroads fiberglass hood with hydraulic shocks, new front windshield glass and gaskets, new weather stripping, stainless steel rocker rappers, new brakes disc front drum rear, proportioning valve, master cylinder lines, top bolt and nut kit. BC broncos tie rod over bushing using F-150 tie rod. 5.5” front Superflex suspension and rear leaf packs. Door hinge rebuild kit, body mounts, bushings kit, brake lines SS, Warn premium hubs, Dana 44 front axle rebuilt w/warn axles. Custom bumpers front and rear with receivers and rear tire carrier. (5) MT 16x8 Classic II rims with 33” Buckshot Maxxis Mudder tires. New fuel pump, new rear 23 gallon fuel tank from Northwest metal products with new filler and vent hoses. Custom Internal Roll Cage from Complete Off Road. Heater, blower, core and seal kit. Toms Bronco Grey leather seats with brackets, DTS lengthened drive shaft. New rotors, hubs, spindles, axles and draglink from BC broncos. Valve cover gaskets. Dual exhaust w/ glass packs. Custom Tonneau Cover for truck bed. Custom cover for storage. Garage kept / stored not driven in the winter. Southern Truck. Very solid No rust.
$15,000 or best
1969 Stock uncut all original paint and panels - I am the 3rd owner Colorado truck. Six cylinder 3 on the tree - new clutch, carb and steering gearbox it is a original full cab but has a factory bulkhead with bench seat. Also two tops for this truck both are very nice full and half tops all original. Failed to mention the PTO Winch. $8,500 or best
Both broncos are not driven in the winter and are stored. for more info please call 248-321-0811 or email remi1566@yahoo.com I have dial up service if you are seriously interested give me a call. Both broncos are in my Gallery..Thanks
$15,000 or best
