    Discuss it more here:
  • The Classifieds forum is a place to buy and sell, not an open forum for people to give their opinions on Bronco values. Unless the seller specifically asks for help on pricing, please don't critique quality or asking price. If you're not interested then move on.
    Thanks!
SOLD Space saving hydrobooster
Status
Not open for further replies.
thegreatjustino
Red Head Grease Monkey
Stockton, CA
Hydrobooster with internal reservoir. No worries about interfering with the engine, intake, throttle, valve covers, etc.
$125 shipped to your door
Includes the two pressure port fittings to get you started on your custom lines.
Bigbeardbiii
Jacksonville
does it bolt straight on firewall or do you need a different bracket? Does the link match-up directly or does that have to be changed/modified? thanks
thegreatjustino
thegreatjustino
Stockton, CA
Nothing about this is a bolt on. Push rod needs to be extended like with other hydroboosters, the bolt pattern on the plate that comes with it does not line up with any holes in the firewall. You'll need to drill new holes or use a bracket or plate of your choice/own making in order to bolt it to stock holes.
Same issues as just about every other hydrobooster - the advantage is the lack of interference with an exterior reservoir.
JGO
That looks almost identical to Astro van booster minus the accumulator. I doubt there is an internal accumulator/reservoir inside, it is possible that the vehicle it came out of had an inline accumulator of some sort which is what provides some more power stops in the event of an engine stall.
toddz69
Yes, it does have an internal accumulator. It's a first gen unit that came only on a few GM cars, including 80-85 Cadillac Eldorados (diesel only), Olds Toronados, Buick Rivieras, and apparently, Pontiac station wagons. My first hydroboost unit that I swapped into my truck about 16 years ago was one of these units.
Todd Z.
Status
