SpareParts Build Thread...Linked and tons!
KyleQ
IIRC the larger the port the more air flow but less air velocity. For low end torque you want smaller port, larger ports for high RPM's.
SpareParts
SpareParts
You are right, but that's where cam and compression ratio play apart too. Mine is making a bunch of torque, probably around 375-400 lbs. at the flywheel from what the numbers I punched in said? The current Edelbrock Performer does great, I ported and gasket matched it as well. My valve lift is .460 intake and .480 exhaust, with a 204/210 duration. It's running around 10:1 or so compression. From what I have read, the factory EFI ported and gasket matched will flow around the same as a GT 40 does stock? We'll see, if it sucks I have another lower intake sitting there!
KyleQ
True - gasket matching is wise to do, I'll be doing the same to my Cobra-R intake to TFS heads.
SpareParts
SpareParts
Here's some pictures of the test fitting. I had to open up 2 of the hole in the upper intake, rear 2, as per the instructions for the adapter. I had to enlarge the one opening on the adapter to get it to line up with the lower intake.
All the injectors tested good and had good spray patterns. I cleaned them all up and resealed them along with cleaning all the rest of the parts.
NYLES
Tryin to catch up? Well off for plugs and find my miss.......check my thread
Youngs Automotive
i am starting a efi swap for a customer today picked up a complete motor from a 93 mustang gt ordering all the other parts tomorrow
SpareParts
SpareParts
I can never do anything the easy way, I pieced mine together! Should get to start tearing mine apart on Sat.
NYLES
think I got a bad injector read my thread see what ya think.... nyles efi issues in chat
SpareParts
SpareParts
Got all the old parts taking off, lower intake is on. I had to stop and take time to polish my valve covers, the make my pictures look bad! I'll modify my fuel lines to enter the rear of the motor and not over the side of the valve cover.
SpareParts
SpareParts
Here's some pictures of the progress and one last picture if the good ole days!
The valve covers look much better! I was just test fitting the upper intake, I had to clearance it too... :)
NYLES
Alright! I just hope your luckier than me! But Ill be ok by the end of the week!
