stock1970
my stock 70 302 bronco failed to start a month ago, it just clicked once as if battery was totally dead, i disconnected the pos and neg cables to battery and reconnected and it started.. then just last week it did it again, i figured the switch was going out so i changed it and the battery cables. i am pretty sure i connected everthing back up to switch correctly but now when i try to connect the battery cables back up it sparks so hard it leaves a spark mark on the battery post.. .. maybe i connected something up wrong from the alternator to the switch and ground i am not sure.. there are two black wires coming out of the atlernator harness of wires along with the others.. are they both ground or what.. all help would be great..
