Seems like 2 grnd is sort of price 'floor' for the aftermarket EFI, with some costing well over 3 grand.
I mentioned it in my earlier post, but didn't push it. Those who aren't familiar, and are looking for an aftermarket system should look into Megasquirt. It's basically an open source, DIY version of the most popular aftermarket efi controllers. Depending on your level of skill and interest, you can go as far as buying a kit with components and unpopulated boards and built it from scratch, or buy completed units that need to be programmed, or buy programmed units and pre-made wiring harnesses. At the cheap end, prices start around the $200 mark plus whatever sensors/injectors you want to run.
MS can be programmed to work with any sensors and components you want to use from stock to exotic aftermarket stuff, and there is a HUGE community of enthusiasts to support the novice programmer and help them figure out what to do next. There are also a ton of one-off custom applications that users have come up with. You can control EDIS distributorless ignitions, variable valve timing, nitrous, water injection, etc etc, you can program from a laptop or PDA, and the unit can be programmed to auto tune once the basic setup is done. For the money I think it's about the most rewarding and versatile system available, although it isn't the easiest system by a long shot. The down side is that you will have to actually learn how efi works to be able to build and program the system (but the MS website has all the info you need).
I've got a full system I pieced together for the turbo mercedes/cosworth I'm building in my spare time. Scrounging the internet, I got all the components I need from the control unit to the injectors to the wideband O2 sensor, fuel rail, pressure regulators, fuel pump, etc etc for about $750.
