I don't know what my gear count is. Mine came originally w/ 3:50 gears in the diff's, C4 auto, Dana 20 T-case, and the stock tires were probably 28" diameter.
Now I'm running tires that are stamped 37" tall, but are actually about 36 3/4" tall, C4, dana 20, and 4:88 gears. I have not used a GPS or other device to try to determine actual speed...but "assumed" its fairly close because of taking into consideration the new tire diameter and lower gears are "about" the same percentage of change based on engine RPM at indicated 60 mph speed?
However, now I want a correct speedo. What steps do I take?
