square tube frontend...
DBrown
Bowling Green, KY
I was thinking of making a square tube frontend that was removable...has anyone done anything other then bending tube?
I don't have access to a bender and think the sheet metal front end is way to expensive to mess with. so has anyone done it? got pic's?
rcmbronc
Tomah WI
I did this onm my trail truck. I used 1" square tubing. I can get pictures later thursday when I am on my other computer. It worked real good.
DBrown
DBrown
Bowling Green, KY
the actual front clip...mine is rusted threw at the sides and was hit at one point so the core support is shot. I just can't see putting that kind of money in sheet metal when you could have something removable and stronger for 1/2 the cost....
br0nc0xrapt0r
Loves pickles
yeah square tube would work really well all you would need is a welder and a chop saw.
sstlaure
Bronco Slacker
1" round tube works fine as well (this is 1" x 0.095 wall DOM)
sstlaure
Bronco Slacker
thanks. It really wasn't as hard/complex as it looks. For the curved portions I bent up multiple 180 degree s-bends to give me various curves to work with. (at my friend's shop) I then completed everything else with an angle grinder (cut-off and grinding wheels) and my MIG welder.
I started by bolting the fenders/grille together and getting the front end and hood to all line up pretty (wood blocks used in various spots to get everything sitting where I needed it.
I then build the structure behind each fender, then the main center section of the core support, then I connected the (2) with the front spars, then cut the spars and welding in the flanges to be able to take it apart. There are more pics in my build thread and you can see how it evolved.
http://classicbroncos.com/forums/showthread.php?t=47631&page=16&highlight=sandrunner
Those little magnetic 45/90 degree blocks available in welding shops are very helpful for getting things lined up for tacking. I had (2) to use and it would have been nice to have a couple more of different sizes (I have the medium size)
DBrown
DBrown
Bowling Green, KY
I was thinking of fabing something more similer to the stock setup but just out of 1"x1" and some angle but making it removable so you can work on the truck easier. using round looks awsome but I just don't have the acces to a bender.
has anyone done a square setup that can post up some pics?
I was thinking of bolting everything together without the dog house on it to get placement on where everytuing needs to go. but this kind of brings up my next question:
does anyone know of a chart that has some measurements on the whole tub?
sstlaure
Bronco Slacker
You could just miter the corners and basically do the same as I did but with square tubing.
Those magnetic blocks would work REAL good on square tubing.
firehawk
Clawson, Michigan
You can get a relatively cheap bender. I bought one from woodward fab co.
I think their website is woodwardfab.com in Michigan. Or if you wanted to fab up something. Try welding some bolts on a thick sheet of steel and use them as bending and holding point. You might have to heat up the square tubing first, red hott.
You could get some 2x2 square tube, about 2 feet of it and slide it into your hitch receiver and weld the bolts to that. When I say bolts, I mean something like 1/2 inch. or bigger.
Or like said above cut and weld.
rcmbronc
Tomah WI
Some pics of a square tube.
sstlaure
Bronco Slacker
And it you want it to be removable....just have the fender struts bolt into the cowl, and once you have your structure welded together in 1 piece, make some flanges, bolt them together, then cut/weld them into your structure.
The first couple pics in my post above are before the flanges went in and you can see the tape and red mark where I was figuring out where to section it.
Here are the flanges after installing
DBrown
DBrown
Bowling Green, KY
rcmbronc: thanks for the pic I just wanted to see what one looked like. do you remember how much metal you have in that so I can call around for prices?
I pland on re-enforcing the fire wall from the inside of the truck where I plan to bolt it then bolt the flanges on and start tacking everything up with the original dog house out of the truck and the fenders and grill set up in place so I get everything square again.
rcmbronc
Tomah WI
I think I used about 30'. Maybe 40'. It usually comes in 20' sections, I would buy 40'.
