I have a 72 bronco with factory power steering. I have replaced all the ball joints seals and bearings. Added disc brakes front and rear with hydroboost. New coil springs and shocks. Stock with no lift.
West Texas Offload rebuilt my steering box and upgraded to a 3 turn lick to lock.
It has about 11/2 to 2 inches slack in steering. Slack appears to be in the steering box input shaft before it tightens up and turns the pitman arm. It is really hard to keep it in the correct line of travel going straight are in turns. It tends to dart when you correct your line of travel. Your steer out of the slack and wow it suddenly darts into the correction.
Any thoughts
Caster 2.9 and 2.8
Camber 0.9 and 1.1
Toe 0.5 and 0.5
Any thoughts
Caster 2.9 and 2.8
Camber 0.9 and 1.1
Toe 0.5 and 0.5
