Stabbing a Duraspakk dizzy
SWBronc
Montgomery, Tx
O.K. Iv'e got the motor at #1 TDC. How do I get the dizzy in the right position to pu it in the block? Thanks for the help in advance.
broncnaz
The vaccum advance canister should be about straight forward then you position the rotor to the number #1 firing position as determined either by cap oreintation or your choice. Basically you can just drop it in and where ever the rotor ends up is where you start #1 wire.
NYLES
get the #1 plug post and rotor button to line up when it goes all the way in
Viperwolf1
electron whisperer
Need to verify #1 is at TDC on the compression stroke before connecting the plug wires.
70_Steve
Old Guy
Factory stock position.
