- May 28, 2013
- 1,824
Im currently doing a 302 to 351w engine swap. I got the 351 running and troubleshooting some odd issues and while under the Bronco I noticed the starter gear was still meshed to the flex plate.
The starter is not turning its just the gear is not retracting back away from the flex plate.
I hit it with the hammer a few times and still would not retract. New starter Tuff Stuff 6124B, new Toms Offroad 164 tooth flex plate and new separator plate. All should be compatible.
https://www.tuffstuffperformance.co...ction-starter-2-bolt-mounting-zinc-6124b.html
https://tomsoffroad.com/CartAdd.do?orderProductCodes=4050&orderProductQuantities=1
https://www.amazon.com/dp/B0BSDTLYJV/?tag=classicbroncos-20
I decided to install my old starter. It turns over the motor fine but also gear stuck to flexplate. I hit the old starter with a big hammer and the gear retracts.
I believe Ford starters dont require shims, but Im at a loss and no other ideas.
If I can figure this issue out, it would be great win as I have other bigger issues with the swap to deal with.
Thanks,
Thanks,
