I'm working with a 94' 5.8 in a 73 with the c4, I'm using the starter from the 94'. I jumped from the starter terminal to the blade terminal on the starter solinoid per tech article http://www.azbronco.org/tech02.htm. The problem is after startup the starter stays engaged for a second or two after startup. So far I've changed out the starter, and solinoid but has made no difference. Any suggestions on what to look for would be appreciated . Thanks
