LilRedBronco
Update- I put this in a later post but should put it here too incase it helps others down the road who search for this info...
***When I got home from work I looked at the old heads to get an idea of what the holes looked like etc. I was surprised to find upon a very close inspection that the machine shop apparently welded/brazed over the old steam holes in the heads and did the same to the block. They apparently bored the block like a newer block with the same passageways. I gotta say they did a masterful job. I found some picts of a more modern 302 to see what the galleys looked like and it is identical. Except that over time and with heat etc the welded/brazed areas are discolored a bit so you can see where the work was done.****
I was looking at the instructions for me new edelbrock performer heads and note that for my old 72 ford 302 it says I need to drill steam holes. It is a bit unclear as it looks like you only drill two.
Now is this something I can do with a drill and drill bit or am I going to need a shop to do it? Is it mandatory or can I get by with out them (please say yes) That sounds a lot like work and not like fun.
If I have to drill I have to beg my wife for the drill since she has hidden it. She is literally the coolest wife ever she never gives me any grief except for the drill.
I accidentally put a rather large drill bit DEEP in to my thigh awhile back (2-3 yrs ago) when I was working on my old Harley. And you know how wimminz always freak out about ER visits, screaming and blood.
Shoulda seen what I had to do after I had an accidental (negligent)discharge with my CCW pistol in the house %)
Protip: Do not ever offer to help me do mechanical stuff unless you want to see me bleed and cry a lot I probably shouldn't say that but I am a bit accident prone and have bad luck.
