bronco_daddy
So I had been a bit concerned about the amount of play in the steering wheel/column in my '73. Bought the full rebuild kit for the steering column and decided today was the day. As mentioned, everything underneath is tight so I have also purchased a Borgeson shaft collapsible. First thing after I removed the Grant steering wheel horn button, I noticed the movement in the steering wheel on the shaft, the nut was not torqued down. Replaced the bearing, sleeve, redid the automatic shift arms bushing, etc and put it back together, torqued the steering wheel and took if for a spin...DAMN. Tight, responsive...adios sloppy steering column and play...best money spent and I have not even replaced the lower steering shaft yet.
