Steering Stabilizer
green73brc
For those who have a stock suspension setup can you tell me how close your steering stabalizer is to the oil pan. I have a new drag link and the manuf is telling me 1 inch is okay... In theory it sounds like there would be no problems but I am just wanting to double check...
Eric
Gummi Bear
Your stabilizer should be fastened to the bottom of the cross brace and to the draglink.
Something weird going on with yours?
Shoot a pic, and post it up. It sounds like something wacky is going on with your mounting.
G
green73brc
It is going from the factory drop bracket from the outside of the frame to the middle ish of the drag link. I have stock suspension so no lift. The new draglink has a slight bend it in as it is adjustable... the old draglink had no bend in it... so now it seems like it is super close. I will see if I can get a pic but it will be later tonight...
airman
Drag links should not have bends. Look at this one that came with my BRonco when I bought it. This picture made Bronco driver and scary steering. I didn't know how bad it was when I bought it.
Enough about me. Why is your drag link bent?
G
green73brc
I can not find the camera but ill just post a link to the drag link... check out the adjustable ones... they are bent to compensate for the adjustable portion to be straight...
Wes harden
pic
This is a pic of my stock 69 no lift hope it helps
TJK74
Newark CA
Here is another pic.
Your stabilizer should be fastened to the bottom of the cross brace and to the draglink as stated above
G
green73brc
Thank you very much that helps an increadibly large ammount..... Thanks everyone...
Eric
