steering wheel and shift collar install tips?
heuer21
Indianapolis
I have a '73 with OEM power steering and a C4 transmission. I had alot of steering wheel play, up and down side to side. I removed shift collar and replaced the bearing and bushing.
I am having trouble installing the collar back and signal housing back on, I cannot seem to get the T-Bolts to set in the holes on the column itself. Anyone have any tips?
I have already watched the video from Wild Horses but his just goes back on like butter. of course.
http://www.youtube.com/watch?NR=1&v=LNTv2kpxba4
Thanks!
Chief Master Sergeant
Retired U.S. Air Force
Yeah, it's kind of a pain in the butt. If you have the nuts on the t-bolts just a thread or two, you should be able to push the nut side in toward the center of the column, which will allow the t-side to slide over the column and into the slots. Easier said than done. Took me a few tries, with the column out of the vehicle.
I wish I had some magic trick to pass along, but it really is just a pain in the butt. Perhaps someone will pipe in with a better answer. I watched that same video three or four times, hoping it would provide something it didn't. Good luck!
thegreatjustino
Red Head Grease Monkey
Stockton, CA
I've always held the bolts in with a dab of grease then slowly installed the signal housing just enough to get the nuts started. Kind of a pain, but I usually get it on the second or third try.
