Steering wheel cancel cam
tampabronco
If I'm sitting in the drivers seat the steering wheel cancel cam ring should be on the left side at 9 o'clock right?
Put the steering wheel back together last night and my left blinker turns on and off when I turn my wheel left. Thanks
jckkys
I've tried it both at 9 and 3. At 9 a slight correction as you approach a stop sometimes cancels the signal. At 3 you need to do a sharp turn to get it to cancel. I ended up going with the 9o'clock position and using a one bump cancelling cam that needs a little more steering wheel movement to catch the lever on the switch.
