steering wheel groan after hydroboost
badandy73
Broncoholic
Did the super duty/ diplomat/Lincoln hydroboost conversion about 6 months ago, started hearing an intermittent groan at the steering wheel shortly thereafter but wanted to get through summer before tearing into it. Hydroboost works amazing, burped and bled it upon install and have had no problems since, just the noise, usually at idle when turning the wheel but not touching the brakes. I suspect the reman pump (74 Lincoln- dual return) I bought from O'Reilly's is failing to keep up properly at idle, and had planned on pulling it for a free replacement in case I got a bad one, but don't want to overlook something easy. Using type F atf for the pump/hydro system, had used that prior with my box(fresh rebuild stock 6 turn) a year ago prior to hydroboost with no problems. Sounds like some of you have had good luck with GM pwr steer fluid, but am I on the right track with suspecting the pump?
badandy73
badandy73
Broncoholic
Yes, swapped it over from my existing(saginaw-single return) pump
badandy73
badandy73
Broncoholic
Worked off of motoman's diagram in his write-up and triple checked everything at the time, high pressure lines all match up, only deviation from it that I knew at the time and now looking at it again are the low pressure (return) lines are swapped. Didn't think the way the return lines went back into the pump mattered, for me the one end of the cooler line ran nicely right into the upper return of the reservoir so that's the way I did it. Maybe the return line out of the hydroboost unit needs to run into that upper return of the reservoir instead?
sykanr0ng
The return from the hydroboost is a lot lower pressure than the return from the power steering box.
Make sure that it isn't getting fluid pushed the wrong way.
Also make sure that the reservoir isn't running low and causing cavitation (aka bubbles, aka foam)
I would suggest either Red Line synthetic power steering fluid or at least the GM power steering fluid.
bronconut73
That Red line is good stuff.
badandy73
badandy73
Broncoholic
Resurrecting this thread..
Still getting noise at the wheel even after swapping about 3/4 of a quart of the type F that was in there with Redline. Definitely an improvement but don't think its going to completely take it away no matter how much I flush out. Debating on whether or not to go back to my old single return pump and running a T or would you guys just recommend swapping my old pump into the dual return reservoir? Will 'T-ing' the return lines together really make that much of a negative difference?
