Steering wheel hub collar help
blamejane
Hey guys, I'm installing a new steering wheel and hub on my bronco. The hub is for a 75-77 bronco, however I can't get collar onto the steering column lip. I've tried using a rubber mallet with a block of wood to hammer, but with the small amount of force I used, it didn't work.
I know the column is stock, and the collar looks like it should slide onto it with some force or pressure, but I don't want to damage it. Thought I'd see if anyone has experience here. What do you guys think?
Here's a photo:
blamejane
blamejane
See if this helps. Your pushing a spring and trying to line up a key way in the shifter tube on top of everything else. It helps to have 3 hands also.
https://www.youtube.com/watch?v=LNTv2kpxba4
Thanks Mike, I've passed that part though; and yes it was tough. I have the hub and steering wheel already installed. The collar I'm speaking about is decorative, and covers the gap (supposedly) between the hub adapter and the steering column. Once it drops down enough to cover the gap, then the set screw is tightened to keep the collar in-place with the hub (as the wheel turns the collar turns with it).
My problem is the collar won't slide over the silver colored lip you see on the top of the column.
blamejane
blamejane
Wrong size collar sent perhaps?
Yeah, that's probably what's going on. I wasn't sure if it should be loose or snug. As I think about it, if I hammer the collar so that it fits over the lip, then it won't spin freely as the wheel turns; it'll be a snug fitting collar.
I'm assuming that it should ultimately be loose NOT snug to function properly.
RM70
Athens, AL
I know the collar in the kit I put on a 66 mustang was fairly loose fitting on the steering column.
blamejane
blamejane
I'll try to grab a picture of it tonight when I get off work.
I appreciate that but not probably not worth the trouble as I'm pretty sure you've already answered my question. Thank you!
blamejane
blamejane
Can someone confirm that silver lip is correct at the top of the steering column, and not some modification made for the previous aftermarket steering wheel/hub? Hope this makes sense to you guys.
56f100bbw
Tucson / lakeside AZ
One piece hub and collar
On my 76 bronco No adapter collar no set screw It’s all one piece with the hub
blamejane
blamejane
Thanks Gary. So looking at this pic, my column may have been modified as your column looks different at the joint. BTW, nice hub...wish mine came like that.
56f100bbw
77 bronco
This is my 77 bronco Nardi hub and collar it has a set screw to hold collar in place on a stock steering column
blamejane
blamejane
Thanks. I have the same hub/collar it looks like, so my problem is the lip. I assumed the collar went over that lip, but now I think these two parts should just mate-up or sit-flush.
Do you agree? Anyway, sounds like the hub and collar are exactly as they should be and I just need to paint that lip black, or 3D print a new collar which will cover that lip (loosely)
Well I feel better, thanks everyone who helped!!
75MIKE
NE Washington
I think someone milled that piece to keep the prior hub from rubbing or............... It would be cool if that gap could be hidden.
blamejane
blamejane
Thanks Mike. My plan is to sharpie or paint that silver lip for now. Next time I feel up to pulling the wheel, I'll just grind that lip off and drop the collar a bit more.
jckkys
The top of the switch housing is cast with a squared top. The steering wheel adapter is supposed to come close, ie no big gap, but neither touch nor fit over the switch housing. Yours looks like it had an adapter that was pushed on too far wearing the lip you see into the switch housing. A new one isn't too expensive here;https://shop.broncograveyard.com/Signal-Switch-Housing-Auto-74-77/productinfo/17050/. As you can see in the BG photo there is no lip worn into the new switch housings.
