Step up from 4BT?
ep67bro
Bronco Junky
Easton, MD
I love the powerstroke motors but for the ease of install and price to hot rod up you got to stick with the cummins. I have seen the 6BT in a bronco and it fit well and had tons of power. Good luck any of the motors mentioned would be bad ass!
fungus
Kaneohe Bay, Oahu
Forget the diesel... Drop a new Hemi crate motor in it! In the years to come, I'd be for experimenting w/ that new 305 HP V-6 that's in the '11 Mustang... Or a Cat 3406b... Or...
Tito
Tito
CB Fire Starter
Bakersfield, CA
Reasons I am looking diesel are that I will be pushing the 6500lb mark pretty easy in weight, would like to get better than 10mpg, minimal computer controls, and want the potential to tow something. WB will be just under 120 but should make for a strong setup that can get the family around as well as take on some trails like the rubicon with minimal potential damage and rock armor in the right places (I know where those places are too!)
Pa PITT
Stephenville TEXAS
Ben / 73 stallion & durtymax .. Yes I say the NV4500 is the best one to put behind the cummins and into our Bronco's. Yes the difference between the gas and diesel 4500 is the size of the input shaft .. You can get a chevy 4500 swap inputs for about $140.00 and you fixed. 4500 has a good low 1st and a good strong overdrive 5th. Don't let the 5th gear nut scare you .. B/S .. Fix it once an you good to go forever. 2nd repairs on 5th gear nut under 1% so who cares..
Tito
Tito
CB Fire Starter
Bakersfield, CA
What does Ramsey think about this project?
This build is in my head so not much Ramsey talk going on but I will have all but the mortgage and student loan gone by spring which is the earliest this project would start. Dave would like my labor rate....free!
Stock68
I'm guessing there are at least 5 builds in your head. Dreaming is free after all.
Pa PITT
Stephenville TEXAS
Hey here's a link post over on 4bt swaps about those NV4500 .GOOF INFO HERE. hope it paste.//www.high-impact.net/transmiss...ear/nv4500.htm.
...How about that.
BroncoBoy72
Marana Arizona
Buy a 6bt truck from 96-98 with a standard. You will spend less money buying a whole truck and making it fit versus buying a 4bt then a nv4500.. I bought and built a 4bt with the inline pump and rebuilt it, added a bigger turbo and so on. For a transmission I built a Auto 47RH with 48RE internals and for the tcase its out of a Rubicon bolts right to it. This package was quite pricey and in hindsight I should have just bought a whole donor 6bt truck. Granted my motor is rebuilt and 1/3 the weight.. Good luck on your swap either route.
