The front brakes on my 74 are sticking. Chevy disc conversion w h-boost. The system has been on for 4 years and has been flawless. I drove it last week and the front brakes are stuck. I cranked the truck pushed the pedal and checked the booster. I took the master cylinder loose from the booster to make sure the pushrod was not stuck and it made no differnence. I loosened th e bleeder screws and no fluid squirted out unless the pedal was depressed. I took of the calipers and everything moves freely, yet as soon as you press the pedal, With the engine on or off the calipers stick.
Could the splitter H-block be stuck and not let fluid back to the master therefore keeping the calipers under load?
