RTV only in the vally X 5 or whatever number I am
Something elso to concider if your chasing a vacuum leak, maybe one, or both of the intake manifold gaskets have shifted a little when to placed the intake back down.
So take your time,
After you really clean both the heads, and the intake
Place the gaskets down on the heads, line them up real carefully, then take a marker, and mark where they line up on each head. You may need to use some masking tape between some of the ports to keep it from moving on you in the next step.
Then sit the intake down, making sure the gasket stays where you marked it, and take the marker and make a line at the top edge of the intake on each the gaskets.
Then remove the intake, remove the gaskets, the line you just drew on the gaskets will be a good guide when you do your final instal.
If the Gaskets slips even a 16th of a inch could cause a vacuum leak
Another thing you could do is get a set of intake manifold studs, one good thing about our 302's or 351's is the manifold bolts screww straight in, not at a angle like most other motors, so we are about the only guys that can use studs on out intakes. With studs you can place the intake down a lot straighter, though the one downside to studs is you have to remove the distributor anytime you remove the intake.
