Stock would start at about 6 degrees before top dead center. If you want better performance most engines will tolerate more initial timing. 12 to 14 degrees will give you a good seat in the pants kick as long as you don't ping. I run 14 degrees on California gas. Start a 6 and work you way up a little at a time as long as you don't get engine pink or hard starting issues.
