Stock 302 Hard start issues when warm.
EarlyBronc74
Central Texas
I've read all sorts of threads but nothing definitive on how to cure the issue.
Stock 302 with 2 BBL carb. Texas weather. After cruising and turning the engine off it sounds like its flooded and if I hold the gas pedal down it will start eventually.
I have the stock choke (mechanical and electric?) with the stovepipe tube coming off the manifold. If I eliminate the exhaust ports that lead into the intake manifold (with small plates) am I going to have cold start issues on cold mornings?
Also the stock spacer for the 2 barrel, can I replace that with something else? Wood, phenolic?
B RON CO
Statesville, NC
Hi, the choke stove pipe says you have an automatic choke.
The choke should be held wide open and stay open with spring pressure when the engine is warm. Try to close the choke with your finger, engine off, on a warmed up engine.
You should be holding the gas pedal down to start a warm engine.
It should start in a few seconds if the carb and ignition tuneup are all good.
Good luck
jckkys
There are a few clarifications needed. Do you have EGR? Is that what you mean by exhaust ports leading into the intake manifold? The EGR carb spacers do heat the float bowl more than the pre-EGR carb spacers. If I recall correctly, the '74 EGR exhaust port is round and so can be threaded to accept a hex head pipe plug. I did mine with the intake off the engine, so I don't know how to remove the chips from the intake cross over. Grease on the tap maybe. Some of the '74 2100s had a PCV port in the back some didn't if yours does get an insulating spacer like this;ttps://www.ebay.com/itm/NOS-1979-1982-FORD-LTD-CROWN-VICTORIA-302-2BBL-CARBURETOR-SPACER-E2PZ-9A565-B/391702503796?hash=item5b3349e174:g:ptcAAOSwawpXwjEG. If there is no PCV port on the carb use one of these;https://www.ebay.com/itm/C3OE-9A589...86&hash=item5d6ddb40f8:g:SLMAAOSw2gxYoCA5,and one of these;https://www.ebay.com/itm/1975-1976-...8AAAOSwVcZco3jY:sc:USPSFirstClass!85711!US!-1 for heat insulation. You need a proper PCV system.
Rustytruck
Did you read the owners manual on restarting a hot engine? Make sure the carb is still sporting the thick base gasket with the plastic rings at the carb studs. Gasket should be about 1/4" to 3/8" thick. Unleaded fuel hasnt helped this one bit. Also if you still have the dual diaphram distributer with the retard function intact it doesnt help any eithor.
bknbronco
North Metro, MN
on my 68 289 i cant touch the pedal. The fuel is at such a great pressure that touching the pedal will dump a shit ton of fuel and floods the motor. Next time just crank it until it starts without touching the pedal.
i would keep the stove pipe choke parts intack.
Warm start issues are the nature of the beast. More than likely you cant fix it. EFI is the only cure i see to my warm start issue....for now i just dont touch the pedal until it starts....sometimes it will crank for a bit but always starts. I can actually head the gas boiling in the bowl sometimes
EarlyBronc74
EarlyBronc74
Central Texas
Ill look into this. Thanks
Justafordguy
I had this same issue here in Florida on 100+ degree days and I'm sure it is caused by our crap ethanol fuel because it's boiling point is only 173 degrees. I was finally able to fix it on mine but it was a lot of work. I installed an aluminum intake, blocked off the exhaust crossover in the intake, added a 1" plastic spacer, and added a large aluminum shield between the carb and intake.
EarlyBronc74
EarlyBronc74
Central Texas
Which manifold are you running? My 302 is stock so I don't know if a 4 bbl would be ideal.
jckkys
Both the intake and heat shield came from mid '80s Mustang 5.0 4v GTs and 5.8 HO 4V truck engines. They are stamped with part # E5TE-9S596AA. I've had little luck deleting the elongated EGR hole in the carburetor mounting pad on these intakes. How did you do it?
blubuckaroo
Grease Monkey
Ridgefield WA
I've blocked the heat riser and installed a thick carb spacer, and still had restarting issues on hotter days. It may not be the engine temperature alone, but also the air temperature in the engine bay. Holding the throttle partialy open helps, but that doesn't keep it from contaminating the oil in the crankcase. If you're having this problem, you should do more frequent oil changes.
Justafordguy
Gary,
Is that where you got the aluminum plate too, did you make it? it looks great. I had one from a 85 Mustang that is now on Kerri's Bronco. It's a nice piece!
Tyler
They did have some heat shields from the factory on the Mustangs but this one came from Holley.
I blocked off the exhaust cross over with the thin stainless steel plates that came with the gasket set and blocked off the EGR hole in the top mounting surface with coarse stainless steel wool and JB Weld epoxy. It has held up for several years like this.
I do believe underhood temp has a lot to do with keeping the carb cool also. I have a hood scoop and cut out the inner fenders years ago, both of which really help keep it cooler under there but the problem didn't go away until I added the big plastic spacer and heat shield.
jckkys
The bowls are on the side. So is the throttle linkage and choke linkage. They can't occupy the same place as a shield. I don't like heat soak percolation hard starts either, but blocking the cross over slows warm up. This is a real cause of oil contamination. If you want the great features of an Autolite 4100 get one. Why settle for an imitation that forfeits some of the best features? At 300 bucks you're not saving money and universal carburetors are set up to run rich, and need to be tuned. 4100s are calibrated at the factory for Ford engines of a specific displacement. No tuning needed. The only motivation to buy a Summit considering these facts,is laziness.
Justafordguy
I'd love a 4100 but have been unable to find one in good or even rebuild-able shape. I have looked for over a year.
blubuckaroo
Grease Monkey
Ridgefield WA
You may be right but I don't know a single person with aftermarket heads who has drilled the heat riser port and exhaust rail to make the heat riser active.
I pick slow warm-up over carb boil over.
I wonder if the "Air-Gap" manifolds would help reduce this carb heat problem?
https://www.edelbrock.com/rpm-air-gap-302-intake-manifold-7521.html
