YellowBronc
Bronco God
- Jan 6, 2002
- 1,830
I thought I was on the right track today in engine repair. Seems I was wrong. I may need some help in trying to diagnose the main problem.
The rundown of equipment:
1975 Bronco but to get the correct spark plugs, we had to use what was called for in a 1974. (possibly replaced engine??)
It's a 302 WITH points. two barrel carb.
This is what's been accomplished so far:
1) Replaced plugs/plug wires/dist cap/rotor/points/ and condensor. A small change but not much. Truck still hard to start and stalls when coming to a stop or going from park to drive.
2) Replaced carburetor with a new unit. Still no tremendous change. After reading about timing chains I thought I would look there. Vacuum gauge reads 12" at idle. With engine not running I can move the crank 12-13 degrees before the rotor in the distributor will turn. (checking the slack in the chain)
3) Changed the timing chain and gears. (Very loose chain. See picture) Vacuum at idle is 14" now. It does run better but still very rough. timing is set at 8 degrees BTDC. It still wants to stall when going into drive. Idle mixture screws on carb are set correctly to get the highest vacuum possible.
It really has no power from a dead start and slow to climb small hills on the highway once it's going. Appears also to have alot of blowby as the PCV can't keep up. It feels to me like a small miss somewhere. Oh, I almost forgot, total advance (vacuum and mechanical) goes to around 32 degrees
I just want to get this running better for the time being until I can get to a different engine that needs pulled out and picked up. Any other thoughts I might try.
My next thoughts are with the ignition???? Coil maybe? Distributor? Or am I beating a dead horse?
