Stock steel wheel question-tire size
mebco09
Does anyone have an idea of what the widest tire you can (should) put on a factory bronco rim.
5 or 5 1/2" rim seems too narrow for a 10.5" tire.
Ill ask this another way:
How do you get stock hubcaps on steel wheels with tires 10.5" wide...without tires looking like balloons?
Thanks in advance.
jray
I have BFG KM3's 31X10.50 on stock wheels. They don't balloon out much at all and no problems with the hub caps Go to my garage under suspension for pics.
unimogger
Philthadelphia
33/10.5/15
Easy fit
Teal68
Inlet Beach
33/10.5/15
Easy fit
That's what I'm running too...
Super sticky tires! Seriously, my first upside down pic! Not sure how to fix that!
If I can find a pic I also had one with 33/12.5/15s on stock rims with cut fenders. I liked the look.
Teal68
Inlet Beach
Found it...33/12.5/15s
And if you do some digging around on the internet you can find one running 35/12.5/15s with about 5.5" of lift. I personally think it looks great.
unimogger
Philthadelphia
If I can find a pic I also had one with 33/12.5/15s on stock trims with cut fenders. I liked the look.
Is that red bronco the one with the 2.5" spring lift/ 1" body lift? Just curious as thats the direction I'm 90% set on
B RON CO
Statesville, NC
Hi, as mentioned, a lot of guys run the 31x10.5 tire on the stock rim. I have done it for a long time with no problems.
There are tire installers who will tell you how dangerous it could be and will not mount them but that is just a CYA policy.
Good luck
Teal68
Inlet Beach
That's correct. I also moved the axle back one inch. Otherwise when it was stuffed the front of the rear tires we're rubbing on the front of the rear opening.
