Strange Fuel/electrical demon - Help?
Yellow75
Sioux Falls, SD
It started about a month ago, and I really hadn't done anything to change the way it was running. After I drive for a while it starts stumbling and barely running. Pull over turn it off for a bit, fire it back up and it usually runs fine again for a while? I was dead set on it being an electrical problem at first, because it was almost like I turned the key off and then back on. The tach would just completely drop to about nothing when it happened.
I have the DUI HEI dist. and traced the 1 wire back to the ignition key and the connection looks fine. SO on a whim I changed the metal fuel filter out for the old glass one that I used to have, thinking it may be boiling the gas. It ran fine all weekend. NO problems at all? Drove it to work yesterday, and home (about 30 miles round-trip) and no problems.. Well on the way to work this morning it started acting up again. Was running like it was running out of gas? It's only about 60 degrees out so I can't see vapor lock being an issue. Have nearly a 1/2 tank and the fuel filter is full of gas.
I know it sounds all over the place and no specific symptoms but that's what's killing me! If I let it idle it will run fine and will run fine 90% of the time. It's seems like it's only when I have to be somewhere or on the busiest road in town!!
Could a fuel pump act like this? Or a bad HEI coil?
broncnaz
I would lean more towards the coil since it seems to be intermittant but it could be either or neither.
broncolove
The Bronco Ranch
S.E. Michigan
My guess is something in the fuel system, What I have seen cause these symtoms before is the sending unit pick up filter being clogged, collapsing, or picking up sediment in the tank. also could be something in your float bowl in the carb. Sounds like you already checked the fuel filter. I would rest of the fuel system.
