strange idle problem
valveamp
Hi. Hope to get some thoughts on what may be going on with my '71. Just recently replaced the engine with a fresh rebuild, less than 1000 miles on it. Everything is stock in the engine as far as I know, stock heads and stock cam. At first, it idled just fine. Now, however, It has a started doing something strange. When I come to a stop, the engine idle RPM drops down to around 500. Normal idle is around 900. Also, when this happens, the idle is rough. Then after a short time, the idle will increase up to normal and become smooth. This lasts about 10-15 seconds after which the idle drops and becomes rough. This cycle repeats. I also noticed today that when it's running low and rough, there is some dark (grey?) smoke coming out of the pipes. Not a lot, but enough to be seen. When it's running at normal rpm, the smoke is not there. I have a Holley Truck Avenger 670 CFM Carb that is only about a year old. It was on the previous engine. The intake is a stock Ford cast iron 4-bbl manifold. I hope that you guys may have some thoughts on what could be causing this.
Thanks.
bigdaddyof4
Vincennes, IN
Engine smoke means trouble! An engine in good running condition should not produce any smoke in its exhaust. Steam is normal, and may appear to be white smoke on a cold morning. But any other type of smoke in the exhaust means something is wrong.
Possible Causes of Exhaust Smoke:
BLUE SMOKE: Bad news because it means the engine is burning oil. The underlying cause may be worn or broken piston rings, worn or damaged cylinders, worn valve guide or valve guide seals.
WHITE SMOKE: More bad news because it means the engine is burning coolant or transmission fluid. If the smoke is coolant, the cause if probably a leaky head gasket or a crack in the cylinder head. If the smoke is transmission fluid, the engine is sucking transmission fluid through a vacuum hose to the transmission.
BLACK SMOKE: Normal for older diesel engines when first started, but you should not see any visible black smoke with a gasoline engine. If you do, it means the air/fuel mixture is too rich possibly because of a stuck automatic choke on an older engine with a carburetor, a leaky fuel injector, too much fuel pressure, or clogged air filter.
Diagnosis of Exhust Smoke:
BLUE SMOKE: Usually smells like burned toast. Check the oil level on the dipstick to see if the oil is low (add oil as needed to bring it back up to the full mark. DO NOT let the engine oil level get too low or serious engine damage will result!. Do a compression check or leak down test to diagnose worn pistons or rings.
WHITE SMOKE: May have a slightly sweet smell if coolant, a burned smell if transmission fluid. Check the coolant level and the transmission fluid level. If the coolant is low and/or the engine has been overheating, pressure test the cooling system to see if it holds pressure. If it does not, the head gasket is probably leaking and needs to be replaced. If only the transmission fluid level is low, add the required type of transmission fluid to bring it back up to the full mark, and inspect the vacuum hose from the transmission for fluid inside. If it is passing fluid, replace the vacuum modulator valve on the transmission.
BLACK SMOKE: Check the automatic choke if the engine is an older one with a carburetor. Check fuel pressure if the engine is a newer one with fuel injection. Also inspect the air filter.
Repairs:
Repairs will depend on what is causing the smoke. If the engine is burning oil (blue smoke), it will probably need rings and valve guide seals, which means overhauling the engine. If the engine is burning coolant (white smoke), the cylinder head will have to come off to replace the head gasket. If the engine is blowing black smoke, adjusting the automatic choke on the carburetor, or replacing the leaky fuel injector or defective fuel pressure regulator, or a clogged air filter may be required.
bigdaddyof4
Vincennes, IN
Yes I did copy and paste this and sorry I didn't answer your problem directly. It seems to me that you have a fuel/air problem. Probably loading up on fuel then burning off the excess. I would double check for vacuum leaks before I attempted adjusting anything. Spray carb cleaner around where manifold meets the heads and anywhere else there is vacuum. If the engine does not change when doing this then I would look into the fuel system.
needabronco
Prescott/Farmington
It could be a couple of simple things before you condemn a new mill. Your clutch could be hanging up and not disengaging right away dragging down the engine at a stop. And/or your carburetor is too big for a 302 and needs to be adjusted properly. It may have worked on your old worn out engine but with a fresh engine it may be too rich? Your timing could be off too, its fairly common to need to adjust timing after a short break in period on a new engine.
I would adjust the clutch first and timing, then try the carburetor before I moved on to other things.
blubuckaroo
Grease Monkey
Ridgefield WA
Check the fuel level. That's easy enough on a Holly by just pulling the plug on the float bowl. It could be a leaking needle valve or float hanging up. How does the engine perform other than at idle?
bronconut73
Fuel is sitting too high in the bowls. When you come to a stop the fuel in the bowls is sloshing around. Adjust the floats. A little unatomized fuel heading down the intake could cause your symptoms.
badmuttstang
redneck grease monkey
This is where I'm thinking to but do have to ask how old is the gas and how long did the carb sit while all the work was done could have gunk built up in carb or something sticking. One other question did you break in the motor correctly after install. I would flush fuel system change fuel filter and check float bowl levels. Looking for vacuum leaks would not be a bad idea along with just double checking everything is torqued done still (gasket shrinkage). Just a few more ideas.
V
valveamp
HI again. I should clarify a little. The Bronco was out about 2 weeks for the engine replacement. That was several weeks ago. It ran fine after that, i.e. Ino idle problems. The problem doesn't just occur when I stop at a light, it happens when I come home and park the Bronco with the engine running, that is it will do this "cycling" thing for a long time while it's running. I checked the float bowl level when it was on the previous engine but not on this one. I'm not sure why it would change unless it got changed accidentally or by mistake, or incorrectly. I checked the timing about 2 weeks ago and it was ok, but that was right before this started happening. My feeling is that it's some type of fuel issue. I have an appointment on Saturday at a dyno place that will check the tuning on a dyno. Guess I'll see what they got to say and go from there.
jckkys
Everything you said in terms of symptoms indicate a problem in the idle circuit. The idle feed restrictions and idle air bleed holes are tiny and susceptible to varnish build ups and dirt. Carb cleaner and compressed air often cure idle problems. Also the gaskets between the metering blocks and main body may have dried out and no longer seal. No reason to do a complete carb rebuild but some new gaskets and cleaning.
Rustytruck
Since the issue is at idle I would be checking the vacuum circut first. Make sure everything is routed properly and no leaky diaphrams. Check your vacuum tree and any vacuum fittings for loose or cracked lines or missing plugs. Mak sure your engine is warmed up and running and take a squirt bottle of water and squirt the exhaust manifold right at each exhaust port by the head. compair the sizzle of the water to the other ports. If you have a cold port it will be evident. Then check its plug and wire connection to make sure everything is functioning properly. If your still running points make sure they are on the wide side of tolerance not the narrow side.
