STREEETCH: What is the maximum . . .
How far would you stretch & why?
  • 12" stretch
    Votes: 13 52.0%
  • 16" stretch
    Votes: 5 20.0%
  • 20" stretch
    Votes: 1 4.0%
  • 24" stretch
    Votes: 6 24.0%
  • Total voters
    25
camomog
Reno, Nv.
You can have a removable top. Go with a custom cage and connect the B-piller to the upright of the cage that should keep it from moving. For the 4 door conversion "lots of notes and measurements", I have seen several stretch jobs all done at home without fancy shops. The other thing to aid with the stretch is string, use stringlines to make sure you are lined up and centered. Good luck
ponyracer
Crestview, Fl, 32539
Go for it man, I gave mine 15" in my driveway. If you get the bedsides from a 60-66 (I think) ford truck then it's MUCH easier. The bedsides in front of the wheels are the EXACT same and make the fab go much quicker.
broncosbybart
That is a wonderful idea and that thought has crossed my mind from time to time but we're getting tired of making high payments. At this point we have decided to get the Cobra paid off & sell her Liberty and get a fuel efficient cheaper car for her. From there we'd just use the remaining budget to go torwards building up our toys. I have taken welding classes and done some minor fab work in the past. My father is an engineer and I feel that if we put our minds together we could tackle a four door build....it may just take us awhile.
believe it or not, you would be money ahead to buy a slightly used 4 door suv- whatever your tastes. building something like you are asking about is VERY involved and time consuming. granted, i don't like body work at all- but have done my fair share of sheet metal work on a stock tub. I'd never attempt something like this. it would take me forever. hopefully there will be some others out there who will counter my negativity.
as an aside, what kind of tools do you have? skills can usually be learned. tools have to be bought.
cobralee
cobralee
Northwestern OK
I have access to most of the tools that are needed to do the metal work. I'm going to have to buy a welder...dad's crapped out on him. One of my buddies is a body man and I know he would be willing to help me out on the finish work.
Tito
CB Fire Starter
Bakersfield, CA
Agreed.
I am now contemplating taking my stretch and turning it 4 door as the drive train and running gear are just what I want. It will be more work than if the body was stock though as I will have to cut and re-measure to put the rear section back to stock. Will also have to rework the cage (sucks) and sliders.
I could sell the body/frame/cage but I doubt I could get much sadly.
If you just want more wheelbase go 12", if you need to fit more people I'd add 24-27" and either 2 more doors or open the door openings up and stretch some inserts making them longer and room to get to the rear.
markperry
I really like that 4 door that cobralee posted, especially the suicide door look!
Gator809
A small town
My 71 is stretched about 12" making it around 106" long. If you think about it, the full size broncos are that length, and they are still very nimble off road. I have 39" pitbulls, and have 24" of clearance from the ground to the frame.
I do notice that on the road the high speed handling is better in the since that the truck reacts a little bit slower to steering inputs and handles washboard and bad expansion joints much better.
And off road I barely notice the loss of turning radius from the stretch, I lose more from running lockers F/R.
Later
Hank
HoosierDaddy
Pics of a real four door conversions within :
Bronco driver did a feature on the green one some time back , I can dig it up if needed.
http://classicbroncos.com/forums/showthread.php?t=146882&highlight=four+door+bronco
gumbydood
If I was gonna do a 4-door, I think I'd cut the doors down a bit. Most 4 doors have doors that are shorter than a 2 doors, since you don't need access to the back through the front doors. You might be able to get away with only a 20" stretch if you were to shave 2-3 inches out of each door.
The hinges on the suicide door photoshop would likely be pretty wobbly. they looked like they were touching each other.
Let us know what you decide,
G'dood
Tito
CB Fire Starter
Bakersfield, CA
G'dood
Bronco doors are 39" long so that one above is a 39" stretch, thats a lot. 26" would cut it right at the vent window and allow the stock glass and all internals to be used, would lighten them up a bit as well. If you suicide the rear doors it allows the bulk of the weight to hang off the solid rear section and double latch in the middle. I would tie the middle into the B pillar of a cage though as well as to a set of rock sliders. JK second set of doors are 29" at their widest portion so 26" should be good enough to get most people in the rear. Not having the wheel well there would also allow for the use of a 60/40 split syle middle seat like on the 90s explorers for access to the rear.
cobralee
cobralee
Northwestern OK
random thoughts
As I sit here contemplating on this concept vehicle something that I think would be really cool is to create "half doors" such as those on an extended cab pickup. The back door opens only after the front door has opened.
