Family cage with maximum headroom
jimebe
I have been researching options for a family style cage but have found little info about who makes solid 6/8 point family cages with maximum headroom.
There are a few that tout the maximum headspace. The All4Fun Tallman cage looks promising and is advertised as maximizing headspace but the outer bar from a to b pillar that angles in before attaching to the b pillar concerns me. as it seems like it would take away some headspace. Many of the cages I have found have that same style. To name a few, the Toms plate cage, Xtreme cage by Protofab, Evolution cage by D and C Extreme.
If any fellow tall owners out there have experience with these cages, could you comment about any issues you might have had with head clearance and what has worked for you?
stretch
Montgomery, TX
I’m going to be watching this post. I’m in the same boat, looking for a tall cage that I won’t rack my head on. Especially with the plan of moving my seat back 2” using Bigjhoov’s bracket.
Yeller
Rogers County Oklahoma
In my opinion Bailie Bilt has the most room of any of the off the shelf cages. The corners are square and as wide/high as possible and still fit a top. I know guys as tall as 6’-8” using them that are happy.
Bailie Cages
When I built my bronco if I hadn’t had some specific design goals I would have just bought a cage from Gordon and bolted it in, but I had to be complicated lol.
79INA69
I also wanted to save time and purchased the JBG family basic cage. Mocking everything up I personally like the look of the cage being at the same height as the windshield frame. There is 3" of height you can add and still bolt a hard top on without a headliner, but it starts to look funny to me. I'm still trying to lower all the seats and tilt them back to make everything safe and below the cage height. Once I put the seats in and sat in it...I realized how little room a Bronco has. I think the best design for the Bronco is the sport style front to back hoops that run from a-c pillars, then straight legs up at the b pillars. This might require more braces and gussets to equal the strength of a traditional b pillar hoop, but gains you a lot more head space. This is what I will do for cage 2.0. Not sure if a company is selling this type of cage off the shelf though.
BGBronco
N A S H V I L L E
Tennessee
I've had a few different cages along the way. Even with my current KE cage, the tolerances are pretty tight so if you want to run a soft top and be able to take it up and down, most of the cages on the market seem to be optimized for that. If you're going hardtop, and not removing it, you could add some additional space but I think it would look 'off' if it's above the windshield / soft top riser bracket. Even on my Defender, all the lines are below the windshield.
You can also extend the windshield frame up by at least a couple of inches with a riser for a soft top. The Rampage is sleeker looking on a Bronco, but the Bestop is taller by enough to clear the stock wiper motor.
The bars would still be above the door frames, but that’s usually not a visual problem.
J
jimebe
Bailie Cages
To me it looks the Bailie Bilt family cage would limit head room since the b pillar goes straight up rather then bending towards the rear like other family cages I have seen. It seems to have more room in the corner but I would be worried about having to sit directly under the cage.
nvrstuk
PNW
I was going to say the same thing that Paul said about the riser for the soft top might give those that care about looks over SAFETY a reason to go with a cage that wouldn't knock them unconscious over looks.
I'll say it...
The cage isn't there to look pretty, it's there to protect your life.
The OP is doing the right thing looking for a cage that won't give him, or his passengers a concussion.
Yeller
I'll say it...
you can ask my wife about knocking yourself unconscious....... have to properly wear seatbelts too.
nvrstuk
PNW
Sorry to hear about the concussion. ;(
Safety should be mod #1 for all those just getting started (and the rest of us too of course)
I just sold a really cool Mustang split bench seat w/armrest that was in Shorty but it wasn't high back. No neck protection-I won't use it!
I've been in one wreck, lady rear ended me doing (WSP estimate) 65mph while I was turning into my driveway at less than 5 mph off our 50mph County road. I was fine, not even sore the next day as I had been rolled thru my fence and into our pasture. My 3/8" logging chain had one wrap around my strg column, tool box on the floorboards at my feet. Could have been really serious. Full cage, high back buckets and didn't feel stiff or sore the next day. Soooo worth it.
Now everything is bolted to the floor so it can't ever com flying forward to rip my head off.
After the wreck I replaced the worthless rear Bronco seat with 2 high back, fully adjustable bucket seats for my kids. They loved 'em and I felt much better with them being protected
nvrstuk
PNW
Here's my concern... the door post area. Nice flat panel but hitting it hard would be like landing on the side of your head on a 10' fall... I've thought of rollbar padding but it looks better than it works according to those I've asked
Yeller
She was driving our buggy and was terrible about not putting on the sub strap and tightening everything up. Bounced hard enough to lift her out of the seat hitting the roof, knocking her unconscious, which caused her to stiffen up and floor it, which caused it to turn and slide backwards off a wall and pirouette upside-down. After a fun fast paced trip to the hospital and a CT scan she was fine with no issues.... LUCKY!
Long story short, she is now the first one to crawl up someone's a..... for not properly wearing seat belts and/or not having a cage.
Exactly! "I don't wheel so I don't need a roll bar" have you ever seen one of these trucks on its lid on the street? its scary, they become really flat. I ordered seats today for the 70' Gladiator, the hope is I can get a hoop inside once I have those installed, if not it will get a bed mounted bar.
nvrstuk
PNW
Whoaaa, what a scary arse story!
Just think of all those "cool ledges" we are within 15' of at Moab that are literally 100 ft vertical then hit a rock outcropping and drop another 100' vertical...
So glad everything turned out fine! Whew.
jmhend
Which KE cage are you referring to? I thought their sport cage was pretty roomy because of the way it mounts to the windshield frame. I too am a huge fan of Gordan's cages (like in my signature).
BGBronco
N A S H V I L L E
Tennessee
I love the cage and I think its perfect. I was referring to the fact that in general, you cant build one much bigger than the KE without interfering with the soft top operation. Thx
jmhend
Ahh, got it. Thanks and sorry for my confusion.
bigjhoov
nobody
I'm somewhat tall and have built a few cages with max headroom as an objective. The hard part is building within the confines of the hardtop. I built this one to fit as tight as I could to the hardtop as I could get it, within about 1/4". I like to lay the b-pillar back about 5 degrees to keep it away from my head, and I think it looks better as well. I would like to redo this one and change a few things to get it closer to the body.
For production cages, I like the Bailie Bilt and the SpareParts cages.
full
full
J
jimebe
full
full
Love the cage. How tall are you? Do you sit under the cage or in front of it?
I have not seen the SpareParts cages. Do you have a link to a site?
